thebadpete
Sep 09, 2021Guide
Upgrade from RBS50 to CBK752, yay or nay?
Hi all, I have been a happy camper with RBS50 for 4+ years. I have recently switched from DSL (can't wait for fiber any longer) to Xfinity, and I am thinking of upgrading to CBK752 so that it is ...
thebadpete
Sep 09, 2021Guide
Thanks! I actually did not realize that the modem portion of firmware of CBK is not getting updated. That definitely changes my plan! Perhaps I will follow your setup to get a NG CM!
I notice that you have RBK853 and you probably had RBK50 before, Is RBK853 worth the extra?
Sep 09, 2021Guru - Experienced User
The modem portion does get updated however not as frequent as the router portion.
CM series modems are good.
I have enjoyed the Orbi AX. Though one item that doesn't work well is NEST controllers. Seem problematic on Orbi AX systems. I don't see this problem on the RBK50 series when I have it online. Other then that, the 8 series is pretty good. Has great coverage and performance. I can't really compare it to the 7 series however knowing that the 7 doesn't have a 2.5Gb WAN port and wireless front haul speeds are just a bit lower than the 8 series, over all, there close to being the same.
If you have AX supporting devices, then it maybe something to check in to. Try one out...
