Coffeecup
Mar 31, 2021Star
Upgrade RBR850 advice
After going through the RBR50 FW upgrade issues (intermittent connection), my Orbi system is running without problems. Initially I thought my Orbi was broken so I purchased a RBR 850 from Amazon. ...
Mar 31, 2021Guru - Experienced User
Would need to trouble shoot the 50 series problems to see if there is a problem in that system first. Recent known problems are that Traffic Meter needs to be disabled on the Orbi AC series FW. Seems to cause problems thats known by NG.
Would be up to you to get a Orb AX or not. Do you have anything that can take advantage of the AX wifi modes?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Coffeecup
Mar 31, 2021Star
My home is wood framed single level 1600 sq. feet.The distance from router to satellite is approximately 30 feet. What advantages does the AX Wifi mode(s) offer? Sorry if this is dumb
question.
