Andy1974
May 18, 2023Initiate
Upgrade suggestion for my RB 752
Hi all, I have used RB 752{AX4200} for two years, I find that it is not powerful enough now. I want to extent the range, so what should I do? Regarding the price of an add-on AX4200 Tri-...
Andy1974
May 19, 2023Initiate
Thanks mate,
How much area are you trying to cover?
two storey, around 330m2
What is the home made from (interior walls)?
Plaster board
Are the satellites hardwired in or wireless?
wireless, master in the upper floor
When you say its not covering anymore, it did before? What changed?
my upper floor is quite long, I just set up a vedio streamer in my room{at a coner}, I found that this area may be too far from the master, so, I think I need to upgrade to 3 packs.
May 19, 2023Guru - Experienced User
Plaster board? Just make sure we're not having a difference in regional dialect.
Does the plaster board have mortar and a wire mesh in it?
If so, it blocks wifi really well and hardwiring in the satellite might make a better difference. Or you could always pickup a cheap renewed/refurbed rbk752/3 kit and use the satellites. (if their speed is good enough for you)
Just curious as 330m2 is right around 3500sqft which the RB752 should cover if spaced properly. (I have the same rbk752 and a home around 3300sqft)
