Corrado97
Dec 28, 2021Tutor
upgrade to wifi 6
Buongiorno a tutti, attualmente a casa ho una fibra ftth di Tim con profilo 1gb in download e 300 in up. La connessione viene gestita dal sistema orbi rbr20 con un satellte aggiuntivo che ho acquis...
- Dec 29, 2021
If its performing and meeting all your needs and goals, I'd stick with that version for now.
Wifi 6 and wifi 6E devices are coming down in prices as well as the firmware gets more mature with each generation.
Unless you're needing to upgrade, I'd hold off because your current system is a pretty solid wifi 5 version.
Dec 29, 2021Guru - Experienced User
Corrado97
Dec 29, 2021Tutor
Hi,
So I'll stay with the current configuration and wait a little longer.
Thanks.
