Shorty86's avatar
Apr 08, 2023
Upgrade to WiFI 6
Hello,   I am looking for some advice on whether I should upgrade from a WiFi 5 Orbi system to a WiFI 6 system.   I currently have a Motorola 8600 cable modem and a 1 GB internet plan from Comcas...
  • F_V's avatar
    F_V
    Apr 12, 2023
    I'll just add my 0.02c since we had similar hardware and layout.  I had an Orbi RBR50 with 3 satellites, one in guest room (closest to garage, about 30 feet), one in basement, one in upstairs office, and Orbi router in living room.  I transfer files around using wireless backhaul and was getting about 30-50MB/sec.  Just upgraded to an Orbi 960 with two satellites.  Local thruput is now about 100-105MB/sec, however the garage coverage is no better than it was before.
