Dustin_V
Sep 30, 2020NETGEAR Employee Retired
Upgrade Your Internet Experience With The Orbi WiFi 6 With Built-in DOCSIS 3.1 Cable Modem
The newest member of the Orbi WiFi 6 family has arrived and it’s packed with features that is designed to meet the growing demands of your home network. The brand new, all-in-one Orbi Mesh WiF...
Kelitk79
Oct 18, 2020Aspirant
I upgraded two days ago (CBK752) with this model and it has been the worst upgrade I have every had to deal with. My 2nd floor devices (Xbox, PC) are dropping 3 times a day. In addition to saying I have no Internet, yet my TV downstairs never loses connection to Hulu or Netflix. My previous older setup never dropped, I simply just didn't have the range for my master bedroom, so don't blame my ISP. Why am I having so many problems with this and why do I need to spend hours trying to troubleshoot something that should work out of the box. I loath having to call Tech support and I'm so pissed off right now.
- FURRYe38Oct 19, 2020Guru - Experienced User
What is the distance between the router and devices?Where in the home is the CBR located? Main or 1st floor centrally is recommended...
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- Kelitk79Oct 19, 2020Aspirant
Hello,
What Firmware version is currently loaded:
Router CBR750: v3.2.16.9, Satellite RBS 750 v3.2.16.6 (no updates)
1800sq ft
Xbox(s), PC, Smart TV are between 15 to 30 feet away from the Satellite
Is the drops happening with both wired and wireless devices?
Drop only happens on the wireless devices on the 2nd floor. Tv on the first floor that is "Wired" does not lose connection.
Where in the home is the CBR located? Main or 1st floor centrally is recommended:
CBR is on the first floor.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.Try disabling the following and see:
I have implemented these changes and will follow up after testing the network.- FURRYe38Oct 21, 2020Guru - Experienced User
Might try the system with out the RBS as well to see if the problem comes at the CBR or not...
Keep us posted...
