Dustin_V
Sep 30, 2020NETGEAR Employee Retired
Upgrade Your Internet Experience With The Orbi WiFi 6 With Built-in DOCSIS 3.1 Cable Modem
The newest member of the Orbi WiFi 6 family has arrived and it’s packed with features that is designed to meet the growing demands of your home network. The brand new, all-in-one Orbi Mesh WiF...
RCK22
Feb 14, 2021Aspirant
I am not sure I was steered correctly at Best Buy. I have internet through Spectrum Cable using their modem and router. I was told this product would give me the stronger WiFi coverage I need throughout my house. The modem and router are at one end and the WiFi is spotty in the center and weak at the other end. The guy told me it was only a matter of disconnecting the Spectrum router Ethernet and power and hooking up the Orbi. I went to do this and the Spectrum router also has a coaxial cable going into it. Their is no coaxial jack on this Orbi router. Do I need a different Orbi?
Thanks,
RCK22
- FURRYe38Feb 14, 2021Guru - Experienced User
What model Orbi did you get? If it doesn't have a coax cable in back, then it's a wifi router system only.
It can work with your isp modem/router. Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first, if that doesn't work, try option#3.
RCK22 wrote:I am not sure I was steered correctly at Best Buy. I have internet through Spectrum Cable using their modem and router. I was told this product would give me the stronger WiFi coverage I need throughout my house. The modem and router are at one end and the WiFi is spotty in the center and weak at the other end. The guy told me it was only a matter of disconnecting the Spectrum router Ethernet and power and hooking up the Orbi. I went to do this and the Spectrum router also has a coaxial cable going into it. Their is no coaxial jack on this Orbi router. Do I need a different Orbi?
Thanks,
RCK22
- RCK22Feb 14, 2021AspirantI typed in my model but I guess it was erased since it wasn’t on the drop down list. (RBK752 AX4200) appreciate you taking the time to reply. I was just trying to get the Wi-Fi stronger and across my entire house. I had hoped to buy something strong that would just give a strong boost to what I have and not be a huge hassle to install. With no coaxial plug it appears this is the wrong fit for me. Sorry, I have no idea how to make the adjustments you describe or even what they mean. I don’t mind returning this product but need to know what model I should look for. Thanks - RC
YOu can use the RBK7 series with your current ISP modem/router. Have your ISP help you configure the modem for you. You can use the modem as your interface for the RBK system. Have someone help you with this.
