2uzfe
May 13, 2021Follower
upgrading Orbi to AX6000 plus CM2050v modem
Hi all, I currnetly have an Orbi system (AC3000 plus the CBR40 modem/router). I am upgrading for a variety of reasons to the AX6000 (RBK853 plus a Nighthawk CM2050 modem). Question is - how d...
May 13, 2021Guru - Experienced User
Power OFF the Orbi AX system. Contact the ISP about seting up the new modem on there network first with a wired PC. Once the new modem is fully setup with ISP and running well with wired PC. Power OFF the new modem, connect the RBR to the new modem. Power ON the new modem, then power ON the RBR and RBS. Should be all thats needed.
