MacHeadNJ
Jun 01, 2020Initiate
Upgrading to a WiFi 6 Orbi System - can I just swap out my old Orbi System ?
I have an older Orbi system (an RBR 50 with 3 satellites). Works well. But I'm thinking of going to an Orbi Wifi 6 system (RBK 753) with several satellites. If i bring in a new Orbi wifi 6 rout...
Jun 01, 2020Guru - Experienced User
You'll have to input the SSID names and PWs you want to use when you go to set up the orbi AX system. It's will be as a new system setup. You can use and is recommended to use same SSID name and PWs from other Orbi system that orbi AX would be replacing. RBS from Orbi AC isn't fully compatible with Orbi AX yet.
Be sure to post about Orbi AX over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
