MacHeadNJ
Jun 01, 2020Initiate
Upgrading to a WiFi 6 Orbi System - can I just swap out my old Orbi System ?
I have an older Orbi system (an RBR 50 with 3 satellites). Works well. But I'm thinking of going to an Orbi Wifi 6 system (RBK 753) with several satellites. If i bring in a new Orbi wifi 6 rout...
MacHeadNJ
Jul 04, 2020Initiate
BTW, thanks for your comments. I swapped-in the new Orbi Wfi6 system. Used the identical SSID and password of the old system. All 50+ devices on my network connected to the new Wifi 6 system. No problem.
Works great.
Thanks again.
- FURRYe38Jul 05, 2020Guru - Experienced User
Glad it's working well or you. Its nice when you can keep using the same SSID name and password.
See you over in the Orbi AX forum.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Enjoy. :smileywink:
MacHeadNJ wrote:BTW, thanks for your comments. I swapped-in the new Orbi Wfi6 system. Used the identical SSID and password of the old system. All 50+ devices on my network connected to the new Wifi 6 system. No problem.
Works great.
Thanks again.
