Dazza762
Jan 06, 2022Luminary
Upload speed stuck after FFTP upgrade Orbi RBK753
I recently upgraded my BT Full Fibre line from 500Mb to the 900Mb option. This is meant to include an increase in upload speeds but whilst my downlaod speeds have increased to expected levels, my upl...
Jan 06, 2022Guru - Experienced User
What speeds are you actually getting on the router?
How are you testing the upload speeds?
Are you testing wired/wireless?
What device are you testing on?
What site/app are you testing with?
Dazza762
plemans wrote:What speeds are you actually getting on the router? 886 Mbps down, 70Mbps Up (should be getting 110Mbps up)
How are you testing the upload speeds? Various methods. Via the router admin page (ookla), Google speed tests. ISP speed tests
Are you testing wired/wireless? Both. Similar results.
What device are you testing on? Mac (wired), Iphone 12 Pro (wireless)
What site/app are you testing with? Ookla app and the websites mentioned above.
Thanks for responding. Answer above.
- plemansJan 06, 2022Guru - Experienced User
I could be a retained QoS setting.
have you tried a simple factory reset?
Does it get full speed connected to the ONT/gateway?What ont/gateway are you connecting to?
- Dazza762Jan 06, 2022Luminary
plemans wrote:I could be a retained QoS setting.
Haven't done a factory reset yet as I was hoping I wouldn't have to.
Unsure if the ONT is getting the full expected speeds. I'll need to plug a device directly into it for that which I've not done yet.
Using an Opening reach fibre ONT.
I would start with directly testing the ONT. We could troubleshoot all day just to find out its the ont so its always good to start at step 1
