computim
Mar 25, 2020Luminary
UPNP RBR850 Firmware 3.2.10.11
Question for the community. Has anyone experiencing issues with UPnP on the latest firmware with the RBR850? I've downgraded and upgraded again but I can not get the UPNP to work? I've factory res...
Mar 25, 2020Guru - Experienced User
As a alternative test, disable uPnP and manually set up some Port Forward rules for your Plex Server?
It's possible that I might not see this issue since I don't use any external remote access to any services I have here at home. I don't use Plex. Though for my xbox game consoles, this is the first version of FW that I'm able to get OPEN NAT status on 1 and 2 consoles, after all other FW version failed and the consoles reported Strict NAT.
Another user and I believe that there maybe uPnP issues as this users son was able to get OPEN NAT on 3 consoles, howver he had to manually set port usaged on each console to attain the OPEN NAT status. Which tells me there seems to be uPnP issues with Orbi AX FW:
Do have two bug reports in with NG in regards to xbox NAT status and one other test that users don't normally use unless your a gamer, NAT Filter when set to OPEN is not working. It reports Port Address Restricted NAT when it should be reporting FULL CONE NAT. So I can't attaing OPEN NAT on two or more game consoles playing the same online game currently. I can if I use my RBR50 which works.
- computimMar 25, 2020Luminary
FURRYe38 Thank you! Yes, I've setup the manual port forwarding and have been able to function correctly. Once I enable the UPNP the service drops and access remotely is disabled.
I'm on the same line of thinking that an issue is present with the firmware. I've opened a ticket and will share feedback.
TIm
- FURRYe38Mar 25, 2020Guru - Experienced User
And to be sure, when you re-enable uPnP, you are disabling PF configurations as well?
What other versions was uPnP working for you? All prior?
I'll add this post to my bug report as well.
FURRYe38 Correct, I disable the UPNP and complete a manual PF>, reboot router, check and all functions with the media server are good. Disable PF> and enable UPNP. reboot router, Renable auto in media server; media server signs in but i snot accessible via remote access. Check router UPNP and no information on requesting port present.
Tim
