computim
Mar 25, 2020Luminary
UPNP RBR850 Firmware 3.2.10.11
Question for the community. Has anyone experiencing issues with UPnP on the latest firmware with the RBR850? I've downgraded and upgraded again but I can not get the UPNP to work? I've factory res...
computim
FURRYe38 Thank you! Yes, I've setup the manual port forwarding and have been able to function correctly. Once I enable the UPNP the service drops and access remotely is disabled.
I'm on the same line of thinking that an issue is present with the firmware. I've opened a ticket and will share feedback.
TIm
Mar 25, 2020Guru - Experienced User
And to be sure, when you re-enable uPnP, you are disabling PF configurations as well?
What other versions was uPnP working for you? All prior?
I'll add this post to my bug report as well.
