rdouma
Dec 01, 2021Guide
UPnP send/receive on RBR850 stops at MAXINT
I have already posted this but on the wrong forum (regular Orbi). I use a software called PeakHour to monitor internet traffic from my Mac. It uses UPnP to obtain this information from the router...
- May 25, 2022
I'm now on V4.6.8.2_2.1.9.
I had encountered this article: https://www.bleepingcomputer.com/news/technology/netgear-fixes-bad-orbi-firmware-update-that-locked-admin-console/. This article points to a thread on Reddit: https://www.reddit.com/r/orbi/comments/uq57b3/my_orbi_access_is_restored_without_factory_reset/i8rleeo/?context=3
So I sent a DM to Christine from Netgear and indeed, a new firmware version was pushed towards my Orbi. All working fine now.
EDIT: spelling.
rdouma
Nov 30, 2021Guide
I use PeakHour on a Mac to inform me about data traffic. After a while it drops to 0. It very much seems the same issue as has been reported before: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/X6-R8000-UpNp-or-snmp-monitoring/m-p/1816959, but that's a post from 2019.
PeakHour provides a FAQ page to detect if the information over uPnP suffers from counter freeze: http://support.peakhourapp.com:8090/pages/viewpage.action?pageId=5603403
As can be seen in the attached screenshot, this seems to be a text book case: it reports EXACTLY max_int for an unsigned 32 bits integer: 4294967295
This seems to be a bug in the router.
P.S.: I could NOT find the model in the model drop down list box; I hope this is the correct forum. Information about model/firmware:
Hardware Version RBR850
Firmware Version V4.6.3.16_2.0.51
GUI Language Version V3.0.1.2_2.1.30.3
Operation Mode Router
CrimpOn
Nov 30, 2021Guru - Experienced User
The User Manual for the RBR850 says on page 130 that SNMP is disabled.
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
Is there a possibility that PeakHour is not actually connected to and monitorint the RBR850 at all?
- rdoumaDec 01, 2021Guide
Thanks for your answer!I wasn't using SNMP but UPnP. If it weren't connected, it would never work, and the thing is it works for a few hours before starting to report zero. Using upnpc we can clearly see that both "Sent" and "Recv" report 4294967295 then, which is *exactly* 2^32 (unsigned maxint). So this does look like simply too small a data type to be able to track the bytes.
Oberon:~ remco$ upnpc -s upnpc : miniupnpc library test client, version 2.2.3. (c) 2005-2021 Thomas Bernard. Go to http://miniupnp.free.fr/ or https://miniupnp.tuxfamily.org/ for more information. List of UPNP devices found on the network : desc: http://192.168.1.1:5000/rootDesc.xml st: urn:schemas-upnp-org:device:InternetGatewayDevice:1 Found valid IGD : http://192.168.1.1:5000/ctl/IPConn Local LAN ip address : 192.168.1.13 Connection Type : IP_Routed Status : Connected, uptime=12553209s, LastConnectionError : ERROR_NONE Time started : Fri Jul 9 00:54:28 2021 MaxBitRateDown : 1000000000 bps (1000.0 Mbps) MaxBitRateUp 1000000000 bps (1000.0 Mbps) ExternalIPAddress = 179.27.215.90 Bytes: Sent: 4294967295 Recv: 4294967295 Packets: Sent: 37829630 Recv: 36722583
