rdouma
Dec 01, 2021Guide
UPnP send/receive on RBR850 stops at MAXINT
I have already posted this but on the wrong forum (regular Orbi). I use a software called PeakHour to monitor internet traffic from my Mac. It uses UPnP to obtain this information from the router...
- May 25, 2022
I'm now on V4.6.8.2_2.1.9.
I had encountered this article: https://www.bleepingcomputer.com/news/technology/netgear-fixes-bad-orbi-firmware-update-that-locked-admin-console/. This article points to a thread on Reddit: https://www.reddit.com/r/orbi/comments/uq57b3/my_orbi_access_is_restored_without_factory_reset/i8rleeo/?context=3
So I sent a DM to Christine from Netgear and indeed, a new firmware version was pushed towards my Orbi. All working fine now.
EDIT: spelling.
rdouma
May 25, 2022Guide
For anyone interested and for completeness; this was solved in the firmware version that broke the admin panel and still works in the patch they released for that.
May 25, 2022Guru - Experienced User
What FW version is that?
- rdoumaMay 25, 2022Guide
EDIT: spelling.
- FURRYe38May 25, 2022Guru - Experienced User
Ok, thanks for letting us know. Glad the v.2 fixed the uPnP issue. I have mine on same version. No issues.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- rdoumaMay 25, 2022Guide
Thanks for the feedback. First thing I did after regaining access to the admin panel was to create a backup indeed.
Apologies for asking a noob question, but how do I mark the topic as solved?
