Kjohn1234's avatar
Kjohn1234
Use an RBR20 satellite with RBR750?
Is it possible to use a RBR20 satellite with a RBR750 2 satellite system? I've plugged the 20 satellite in but it's no syncing.
  • FURRYe38's avatar
    Aug 16, 2021
    Not as a satellite. You can configure the RBR20 for AP mode and use it as a wired AP. Will not be appart of the same wireless mesh system and will be it's own SSID and wifi signal. RBRs can't work as RBS.
