rayjai
Aug 19, 2022Guide
Use another router to repeat mesh wifi outdoors
Hi, I have poor wifi signal outside my home, I am trying to have the wifi reach the gated entrance of my home. Is it ok for me to use my old non-mesh wifi router to repeat the signal? will it still s...
Aug 19, 2022Guru - Experienced User
What orbi model do you have?
What router do you have? It depends, if this model router has a repeater function support, it maybe possible to use this to repeat the signal from the Orbi system. If no, the only other option with this router would be to ethernet connect it and configure AP mode on the router which would make it its' own wifi signal and would need to use separate SSID name and channels far apart from what the Orbi system uses.
Other suggestion would be to try a EX7500, 7700, 8000 or EAX30 or EAX80 wifi extenders.
- rayjaiAug 19, 2022Guide
I have the RBS750, my old router is a Tenda ac1500. The Tenda has these repeating options, WISP and Client+AP.
I would like to keep the SSID the same if possible, if not, i guess i'll have to change it then,
What's the difference between, EX7500, 7700, 8000 or EAX30 or EAX80 wifi extenders and another satellite?
Thanks!
- FURRYe38Aug 19, 2022Guru - Experienced User
You'll have to contact Tenda for additional help and information regarding there product.
EX and EAX do same thing however wont' have the wireless/wire backhaul support or UI integrate into the system like the RBS will.
I know how to setup the repeater, but I'm not sure if it's ok for the wifi signals to mix if they have the same SSID. I'm not familiar with how wifi signals work.
Would the ex2700 work?
