rayjai
Aug 19, 2022Guide
Use another router to repeat mesh wifi outdoors
Hi, I have poor wifi signal outside my home, I am trying to have the wifi reach the gated entrance of my home. Is it ok for me to use my old non-mesh wifi router to repeat the signal? will it still s...
rayjai
Aug 19, 2022Guide
I have the RBS750, my old router is a Tenda ac1500. The Tenda has these repeating options, WISP and Client+AP.
I would like to keep the SSID the same if possible, if not, i guess i'll have to change it then,
What's the difference between, EX7500, 7700, 8000 or EAX30 or EAX80 wifi extenders and another satellite?
Thanks!
Aug 19, 2022Guru - Experienced User
You'll have to contact Tenda for additional help and information regarding there product.
EX and EAX do same thing however wont' have the wireless/wire backhaul support or UI integrate into the system like the RBS will.
- rayjaiAug 19, 2022Guide
I know how to setup the repeater, but I'm not sure if it's ok for the wifi signals to mix if they have the same SSID. I'm not familiar with how wifi signals work.
Would the ex2700 work?
- FURRYe38Aug 19, 2022Guru - Experienced User
As long as the distances between the repeater is at a good range, say 30 feet from the RBR or RBS, to find the good wifi over lap between them you'll be fine.
Something to try and see. I have a EX7500 and 7700 and they work when I had them connected.
