Rudy69
Aug 05, 2021Tutor
Use as router only
I have a CBR750 modem router and had cable, but recently switched to fiber. Can I use this as router only?
Aug 05, 2021Guru - Experienced User
Not as far as I'm aware.
some of the older modem/router combo devices could be put in a sort of "access point" mode.
I don't have one to test it on but the CAX series hasn't been able to follow the same procedure. They end up in a boot loop.
I know FURRYe38 had/has one and might be able to tell you if it ends up in the same boot loop.
