Rudy69
Aug 05, 2021Tutor
Use as router only
I have a CBR750 modem router and had cable, but recently switched to fiber. Can I use this as router only?
Aug 06, 2021Guru - Experienced User
You can only use the CBR750 as a gateway modem/router or as wired AP device, not a router. To do this you would need to disable the DHCP service on the CBR750, set the CBR750 IP address to something different or to what you use on a host router system. Diable any Armor features. Then connect the CBR750 to the host router using one of the LAN ports in back.
- jtw1979Jan 09, 2022Aspirant
So I am moving to a place that offers free internet via Ethernet in the rooms. Can you confirm and explain how I might use my CBR750 as a wireless AP so I can have all my wireless devices connect through that and create a home network? Thank you!
