Rudy69
Aug 06, 2021Tutor
Use as router only
I have a CBR750 modem router and had cable, but recently switched to fiber. Can I use this as router only?
Jan 10, 2022Guru - Experienced User
jtw1979
Jan 10, 2022Aspirant
I literally just disable DHCP and assign it an IP address? (I don’t use Armor.)
Do I put it in Bridge mode?
- FURRYe38Jan 10, 2022Guru - Experienced User
Correct, give the CBR a IP address thats with in the domain of your host router. And usually outside of the default DCHP IP address pool. I would use 192.168.#.75. Disable DHCP server on the CBR, apply the change and let the CBR reboot. Connect the CBR to the host router using one of the LAN ports in back.
Only think to know is that the front LED on the down will always blink. I suggest using a postit note over the LEDs to hid them.
