WLF1's avatar
WLF1
Follower
Feb 05, 2021
Use ORBI to Connect MR1100 Hot Spot Router to LAN
We presently have a wired LAN, with about 40 ports, that goes to to two 24-port ethernet switches, and then to an ATT DSL modem.  We want to change to ATT wireless internet service, and ATT sent us a...
  • plemans's avatar
    Feb 05, 2021
    correct.
    you'd want to go MR1100-->orbi router--->switches/satellites/devices.
    the mr1100 has integrated router as well as the orbi. What is Double NAT? | Answer | NETGEAR Support
    so you can put the mr1100 in passthrough mode and leaving the routing to the orbi or leave the MR1100 in router mode and put orbi in access point mode.
