JS4's avatar
JS4
Use RBS750 as stand-alone AP/extender
Can a RBS750 satellite be used as a stand-alone access point and/or range extender?
A friend has just the satellite and wants to extend wireless coverage in his house, beyond what is provided by his ISP supplied router.
I'm unfamiliar with Orbi systems, but told him I would check it out.  Everything I've found online refers to using the satellite as part of an entire Orbi installation.  Thought I'd ask the community as well.
Thanks.
  • No. All Orbi AX and AXE and BE series RBS require to be connected to the host Orbi RBR router.
