UrbanL
Apr 16, 2020Guide
using 2 Orbi RBR850
Hello - I have a relatively large house >280 square meters. From the room coverage it would be very helpful to connect two "routers" via LAN cable and then cover the area with one satellite each. I b...
- Apr 18, 2020
No, you'll still have MESH and a signle SSID name if you connect the RBS to the RBR. The only thing that changes is the backhaul method, goes from wireless to wired is all.
UrbanL
Apr 17, 2020Guide
Okay - maybe I didn't make myself clear. Of course I only want to have one network, but from the room situation there is no good WLAN transmission possible between the two routers. Would it be possible to connect a satellite to the router via a LAN cable? I would have a router (with one satellite over WLAN) and then a satellite (with another satellite over WLAN). With this I would probably cover the building perfectly.
Apr 17, 2020Guru - Experienced User
Yes you can connect RBS to RBRs via ethernet:
The two systems would not be connected wirelessly as a mesh system. You would have two separate wifi SSIDs. RBRs can not be used like RBSs as well.
- UrbanLApr 18, 2020Guide
thank you very much for the quick response. Just so I understand correctly. I can attach a satellite to an Orbi Router RBR850 via LAN cable but then mesh would no longer work and I would have two SSIDs again, which means two different networks. This is of course not what I want. I want to connect a mesh network to a router and depending on the satellite either via WLAN or LAN cable. If I've got this right, I can't do that with Orbi. Is that right?
