UrbanL's avatar
UrbanL
Guide
Apr 16, 2020
using 2 Orbi RBR850
Hello - I have a relatively large house >280 square meters. From the room coverage it would be very helpful to connect two "routers" via LAN cable and then cover the area with one satellite each. I b...
  • FURRYe38's avatar
    No, you'll still have MESH and a signle SSID name if you connect the RBS to the RBR. The only thing that changes is the backhaul method, goes from wireless to wired is all.
