fdormoy
Feb 20, 2023Aspirant
Using 2 separate Wi-Fi Mesh system - will there be interferences ?
Hello, I currently have a Eero mesh wifi system associated with a modem from a current internet provider (Telmex in Mexico). The Eero system was bought in 2019 (so not the Eero 6 system). It works...
- Feb 20, 2023
Just personally.....
- I would tend to avoid having two local networks in the house because of the hassle of changing devices from one network to the other (and back again, and again, and again...) What would be the signal, "it's time to switch"??
Devices on one network will not communicate easily with devices on the other. Say the printer is on eero, but the computer has been switched to Starlink. How do you print? This would interfere with all sorts of common applications. Something as simple as Chromecasting a video. "oops. phone on eero. Chromecast on Starlink." - I would examine connecting a WAN Load Balancing router, both Internet Service Providers (Telmex and Starlink) and use it to balance the internet load across both services. Here's a description of how it works:
https://help.ui.com/hc/en-us/articles/205145990-EdgeRouter-WAN-Load-Balancing
Ubiquiti is a popular brand, but may be in short supply. Trendnet TWG-431BR is another. TP-Link ER605 V2 is really inexpensive ($59US on Amazon). I've had really good luck with TP-Link. For $59US, I would probably buy it and "see what happens." If it's a dud, either send it back to Amazon or take a hammer and reduce it to tiny bits. - At first, I would simply connect the existing eero network to the Load Balancing Switch.
One network in the house.
One WiFi system. - Replacing the existing eero WiFi system is (to me) a separate topic. Of the 40 devices currently on my network, precisely two support WiFi6 (802.11ax) What benefit will the other 38 devices gain from upgrading the router to WiFi6? (hint: not much) And, of course, the RBK852 does not support WiFi6E (6GHz) which I have zero devices that support.
- What about coverage? The RBK852 might provide greater WiFi coverage than the eero. (But, so might a newer eero.)
fdormoy
The house is a rectangle with 30 ft large and 105 ft long (about 3,100 sqfts). The problem is that all rooms are one after the other in an alignment.
The two modens (Starlink and the other one) are in a same room with 2-3 ft apart. I cant really displace the Startlink. It has been already configured that way. Placing it in another room will be quite complicated in terms of linking it to the antenna on the roof.
May be the solution would be to install an ethernet hub with a switch which give me the choice of using the Netgear Orbi 6000 either with Starlink or with the other modem. Would that work ?
Of course, it would mean to get rid of the Eero system...
Feb 20, 2023Guru - Experienced User
Starlink already has a router built in doesn't it?
If you go with a ethernet switch between the ISP host and your two systems you can do that.
Also you could run the Orbi or Eero in AP modes as well and use the ISP system as the host router.
For that size of home, you really only need a Orbi RBR and one RBS.
Running too much wifi can cause problems as well:
- fdormoyFeb 20, 2023Aspirant
...and a third one for the garage which is 15m distant from the router and separated by a thick concrete wall 3 meters tall. Is that true for the 3rd unit ?
