RedredZimmer's avatar
RedredZimmer
Follower
Nov 08, 2022
Using a non orbi wired access point with RBK852
I want to add a wireless access point into my network with the same SSID and password as my Orbi.
The device would be connected to my router Orbi via the appropriate cable but I am wondering if I am likely to have any conflicts with the Orbi wireless network.
Would I be better to buy another Orbi satelite?
Thanks in advance!!
1 Reply
  • plemans's avatar
    If it was me, I'd buy another orbi. You can do as you're wanting but it won't integrate into your orbi system. Your AP should be using a different wireless channel for 2.4ghz/5ghz if its a separate AP (non orbi) to prevent interference.  Plus devices won't roam as efficiently as its not integrated.
