JackInOz
Apr 04, 2021Follower
Using American Orbi in Australia
Hi all,
Family member came back from the US with his Orbi AX6000 mesh wifi router and i was wondering if I could use it in Australia.
Looks like I need to replace the power adapter as it say 110-120v which is annoying but was wondering is there anything else I need to be concern when trying to install it here locally?
thanks all in advance.
Cheers
Jack
1 Reply
You'd want to change the region to australia because each region has their own broadcast restrictions. The North american ones tend to be locked. I don't have a orbi ax so I can't confirm it works but take a look at this post about changing it for the AC version.
https://community.netgear.com/t5/Orbi/Change-region/td-p/2025003
