Edwardlotz
Aug 28, 2020Guide
Using an external dhcp server need to adjust satellite ip address
I am using an external dhcp server that gives out all the IP address in this range: 192.168.2.1 The Orbi rbr850 router is 192.168.1.1. I have the dhcp in the router turned off. The satellite is ...
Aug 28, 2020Guru - Experienced User
Configure the RBR for AP mode and use your external DHCP server for your IP addressing. RBS can't be set manually to a static IP address. Needs either access to a host DHCP server or use of the RBR in router mode with DHCP server enabled.
Edwardlotz
Aug 28, 2020Guide
If I set to APP mode do u need a router somewhere. My dhcp server is not a router. I might be confused about AP mode
If you set on AP I guess the RBR850 will get an IP address assigned by the external dhcp server.
Thanks
Thanks
- FURRYe38Aug 28, 2020Guru - Experienced User
Well you need something infront of the RBR in AP mode to service IP and DNS addresses for internet access.
