mafia2303
Jan 29, 2022Aspirant
Using An Orbi RBK 852 With Hikvision CCTV
I have eight CCTV cameras sited around my house, these are hard wired to an NVR located in my loft which is linked via HDMI to a monitor in my study and an eternet lead runs from the NVR to the study...
CrimpOn
Jan 29, 2022Guru - Experienced User
mafia2303 wrote:
I tried connecting to the wi-fi via a cheap TP Link and it works perfectly!!.
Can you please explain in more detail how the TP-Link WiFi extender is configured?
- mafia2303Jan 29, 2022Aspirant
All i can tell you is that there are two plugs that go into the wall and you connect one to the Orbi by ethernet and the other you connect to the NVR also by ethernet ( having first paired them)
- CrimpOnJan 29, 2022Guru - Experienced User
Maybe the model number of the TP-Link device?
It is a TP Link AV600 TL- PA4010
