mafia2303
Jan 29, 2022Aspirant
Using An Orbi RBK 852 With Hikvision CCTV
I have eight CCTV cameras sited around my house, these are hard wired to an NVR located in my loft which is linked via HDMI to a monitor in my study and an eternet lead runs from the NVR to the study...
Mikey94025
Jan 29, 2022Hero
mafia2303 wrote:I have eight CCTV cameras sited around my house, these are hard wired to an NVR located in my loft which is linked via HDMI to a monitor in my study and an eternet lead runs from the NVR to the study and is plugged into my RBK852 satellite. I use Hikvision cameras and NVR and I use the HIK-connect app on an iphone and ipad.My wi-fi speed is around 550mbs via Virgin cable.
The Orbi satellite was previously used before using the power line devices.
OP stands for "original post(er)", i.e., you. It sounds like your Orbi setup was also connected via power line devices. It would be helpful for us to confirm the network connectivity in detail between your router and the satellite(s). You are saying your Orbi satellite was "hard wired" through power line devices to the router, right? Also, are there also any network switches between the Orbi router and satellite (they can sometimes cause connectivity problems)?
For simplicity, it may be best to start with removing the power line devices and first observing how the Orbi performs with the satellite just wirelessly connected to the router. If that still exhibits the problem then we will take next steps.
