mafia2303
Jan 29, 2022Aspirant
Using An Orbi RBK 852 With Hikvision CCTV
I have eight CCTV cameras sited around my house, these are hard wired to an NVR located in my loft which is linked via HDMI to a monitor in my study and an eternet lead runs from the NVR to the study...
CrimpOn
Jan 29, 2022Guru - Experienced User
mafia2303 wrote:
NVR is in the loft but the ethernet lead comes through the ceiling into an upstairs bedroom which then connects to the Orbi satellite.
The main Orbi router is downstairs.
Thanks. My opinion is that the ethernet lead going through the ceiling is faulty (bad crimp? bent pin? cable kinked? - something)
Is it a single cable, or are there ethernet wall jacks involved?
mafia2303
Thanks for your opinion but I'm not sure you are right- when using the TP Link, there are no issues and I am using the same ethernet lead so why wouldn't i have the same issue using this i method?
It is a single cable with no jacks.
