grimslade
Mar 13, 2021Tutor
Using CBR40 in bridge mode with RBR750
So I recently (today) acquired an RBR750 mesh wifi router (and three satellites) to improve coverage and performance in my home. I've been using the CBR40 as modem/router, but I have serious dead spo...
Mar 14, 2021Guru - Experienced User
After you put the CBR into bridge mode and after you hit apply, reboot or power OFF the RBR750 for 30 seconds then back on. Should have Internet here. Check the RBRs web page under basic tab to check the status of the internet connection after the RBR comes back online.
- grimsladeMar 14, 2021TutorThanks. This did not work. Rbr750 shows 0.0.0.0 for gateway, dns, etc. It’s like the 750 can’t talk to the CBR40 at all when the modem is in bridge mode. I asked Spectrum if we could try registering the router with them but they insisted that wouldn’t work. I may just try it myself. Anyone here have any experience with this?
- FURRYe38Mar 14, 2021Guru - Experienced User
Ensure the WAN port of the CBR40 is being connected from the WAN port on the RBR750.
Swap LAN cables. CAT6 is recommended.
- grimsladeMar 15, 2021Tutor
Thanks. There is no WAN port on the CBR40.
Nothing worked. Spent three hours on the phone with NetGear support last night. As soon as the CBR40 goes into Bridge Mode, we lose all communication with it. Same thing happens if you merely turn off the DHCP server on the CBR40.
Looks like a new cable modem is in my future.
