grimslade
Mar 14, 2021Tutor
Using CBR40 in bridge mode with RBR750
So I recently (today) acquired an RBR750 mesh wifi router (and three satellites) to improve coverage and performance in my home. I've been using the CBR40 as modem/router, but I have serious dead spo...
Mar 15, 2021Guru - Experienced User
And even if you power OFF the CBR and back ON with a wired PC connected to the LAN Port #1 do you not get any on this one PC?
grimslade
Mar 15, 2021Tutor
Exactly. Zero, zip, nada. I’ve tried with manual IP address or not. Once the CBR40 goes into bridge mode I lose all contact with outside world. And with the cable modem. Only way to recover is a hard reset of the modem
- FURRYe38Mar 16, 2021Guru - Experienced User
Thats not good. Seems like something NG support should review. Only other thing to do is that you could run it router mode, set channels between the CBR and RBR to far appart channels. Channel 1 and 36 on the CBR and 11 and 48 on the RBR.
