GOSPDRCR57
Jul 31, 2022Aspirant
Using CBR750 with WPA3 as a bridge for WPA2 printer
I can't believe I have to post on this forum instead of getting proper instruction with somebody from netgear but here we go... I have a CBR750 mesh system with WPA3 enabled, my printer i just bo...
Jul 31, 2022Guru - Experienced User
You'll need to set WPA2 mode on the CBR if you want the printer to connect.
- GOSPDRCR57Jul 31, 2022Aspirant
but the whole of point of choosing this router was for the wpa3/wifi6 capability running it in limp mode seems counterintuitive, could it be done with a rasperry pi and a printer server?
- FURRYe38Aug 01, 2022Guru - Experienced User
Something to ask the printer Mfr about. It's there product that doesn't support WPA3. It needs WPA2 or try ethernet if the printer supports that.
- plemansAug 01, 2022Guru - Experienced User
If you're all about that printer connecting and it won't connect to wpa3 (and you're dedicated you have to use wpa3), either use an old router and set it up in AP mode with wpa2 running. Or just run the Orbi in wpa2 mode.
- CrimpOnAug 01, 2022Guru - Experienced User
GOSPDRCR57 wrote:
but the whole point of choosing this router was for the wpa3/wifi6 capability running it in limp mode seems counterintuitive, could it be done with a rasperry pi and a printer server?
This is indeed the situation. Someone wants to secure his house, so he installs expensive Medico locks with those special keys that are difficult to pick and cannot be duplicated by ordinary locksmiths. Then he says, "oh, but I want to be able to open a door with my old Kwikset key." No. Secure means secure. Frankly, I am amazed that the printer is the only device that cannot connect.
Almost anything can be done with a Raspberry Pi. Or, get a WiFi extender that will connect to the Orbi with WPA3 and create a WiFi access point with WPA2.
- GOSPDRCR57Aug 01, 2022Aspirant
Does WPA matter if it's plugged directly into a satellite via ethernet? Thats how i have it setup now, and I can see the printer on orbilogin but the printer is still telling me its offline
No. I would connect the printer to the RBR via ethernet. Then try to connect to it.
WPA is WiFi authentication. Ethernet connections have no authentication. If the printer is connected with an internet cable and appears on the Orbi Attached Devices display, then it is "connected". Many printers have settings where the user must select Ethernet, USB, or WiFi. Perhaps the printer has been told to use WiFi and does not recognize the Ethernet connection.
