Dazza762
Aug 22, 2021Luminary
Using Orbi AX4200 with BT FTTP
I've recently upgraded to BT FTTP and now have an Openreach ONT (Nokia version). I'm thinking of getting the Orbi AX4200 mesh system as the BT Smarthub 2 is even worse that the original Smarthub. I'm wondering if anyone knows if I'll be able to connect the Orbi router directly to the ONT and fully ditch the Smarthub or will I need to keep the Samrthub in the system?
From what I've been reading I'm hoping I can conect the Orbi router directly to the ONT and just use PPPOE to enable access.
What is the model# of the Internet Service Providers modem/ONT or HomeHub the NG router would be connected too? If there is a built in router at the ONT or modem, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- Dazza762Luminary
Thanks Furry. It's a Nokia made fibre ONT only. No router in it, just modem type function.
I'd ask the ISP to see if the RBR can replace there router after the ONT. I presume it could.
