inktankmatt
May 04, 2020Aspirant
Using Orbi RBK852 with DrayTek Vigor 130 modem for IPTV (BT TV)
Hi Everyone, I've just purchased an RBK852 2 pack and want to connect it to a DrayTek Vigor 130 modem. I have the router connected currrently to the BT Home Hub 5 (with wireless turned off) at th...
May 04, 2020Guru - Experienced User
I would ask your ISP if there services required the use of there router or not. Having two routers on the same line can cause problems.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- inktankmattMay 04, 2020Aspirant
Thanks - I'll try that. I don't intend having two routers in the setup. The plan is to replace my unreliable Home Hub 5 with the DrayTek Vigor 130 modem.
Most of the information I've seen states that I need to set the router to 'router' mode, or change the IMGP Proxy. I've no idea how to do either of those things with the AX6000 so any information you have on how to do that would also be great.
- FURRYe38May 04, 2020Guru - Experienced User
Only thing you can do is enable or disable IGMP Proxy on the RBR. Under Advanced Tab/Setup/WAN Setup.
