inktankmatt
May 04, 2020Aspirant
Using Orbi RBK852 with DrayTek Vigor 130 modem for IPTV (BT TV)
Hi Everyone, I've just purchased an RBK852 2 pack and want to connect it to a DrayTek Vigor 130 modem. I have the router connected currrently to the BT Home Hub 5 (with wireless turned off) at th...
inktankmatt
Thanks - I'll try that. I don't intend having two routers in the setup. The plan is to replace my unreliable Home Hub 5 with the DrayTek Vigor 130 modem.
Most of the information I've seen states that I need to set the router to 'router' mode, or change the IMGP Proxy. I've no idea how to do either of those things with the AX6000 so any information you have on how to do that would also be great.
May 04, 2020Guru - Experienced User
Only thing you can do is enable or disable IGMP Proxy on the RBR. Under Advanced Tab/Setup/WAN Setup.
