oregonbob
Jul 06, 2020Aspirant
Using Orbi RBS750 satellite with RBR850 router
I have an Orbi RBK 853 which consists of 1 RBR 850 router and 2 RBS 850 satellites. I need a third satellite and none of the RBS 850 are currently available. I bought an RBS 750 satellite and it wo...
oregonbob
Jul 08, 2020Aspirant
Thanks for that reply. So far, the RBS 750 seems to be working very well but I'm still searching for an RBS 850 before the return window for the RBS 750 expires.
Jul 08, 2020Guru - Experienced User
The wait maybe longer due to the current world events are going.
- oregonbobJul 08, 2020Aspirant
I ordered another RBK 853 on Amazon. Should be here Friday.
I needed one more RBS 850 satellite and could use a second for a less than ideal area. The first one is for a basement that is a room-within-a-room, framed in metal and insulated with foiled rigid foam. Not a good area for signal penetration. The less than ideal area has an elevator between it and the nearest satellite. It works, but not well. The RBK 853 should solve both problems. Both will be wired backhaul.
The RBK 853 has two satellites - plus an RBR 850 which I don't need. More $ than I wanted to spend but I'm happy with the initial RBK 853 so I think it was a justifiable investment - at least that's what I'm telling myself.
- FURRYe38Jul 09, 2020Guru - Experienced User
Thats alot of money. LOL.
Good Luck.
- HogwartsJul 21, 2020GuideI don’t really understand why the product team ALLOCATED NO UNITS for satellite add on’s ? I can’t cat tell if it’s just bad planning, not being customer focused , Or just greedy about maximizing revenue. Regardless it’s not acceptable, My network is not functional, Because I can’t reach all my devices.
