oregonbob
Jul 07, 2020Aspirant
Using Orbi RBS750 satellite with RBR850 router
I have an Orbi RBK 853 which consists of 1 RBR 850 router and 2 RBS 850 satellites. I need a third satellite and none of the RBS 850 are currently available. I bought an RBS 750 satellite and it wo...
Oct 19, 2020Guru - Experienced User
If your wifi devices are AC mode supporting, then yes. These tend to max at around 400-500Mbps depending on there design and support.
Pcyc wrote:
I have ATT fiber and getting 930-960mbps. But my wireless through my Orbi 750 is only 350-400. Is that about normal?
oregonbob
Oct 19, 2020Aspirant
I don't have any WiFi 6 wireless devices yet. Your wireless speeds are much better than mine. I'm seeing 150-200 most of the time.
- FURRYe38Oct 19, 2020Guru - Experienced User
What mfr and model# devices do you have?
- Mikey94025Oct 20, 2020Hero
More info and expected max wireless speeds in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
