Dazza762
Aug 26, 2021Luminary
Using Orbilogin on Safari
I'm unable to use the orgilogin site on Safari. If I try to access the site it says I need to be connected to my orbi network, which I am. The only thing I could access (by using the specifi IP for t...
raven_au
Aug 27, 2021Virtuoso
Dazza762 wrote:
I'm using that version of Safari but the Orbi site is convinced I'm not connected to my Orbi network. I definitely am as it's the only network in my home. Guess I'll just have to stick to using Chrome for this specific site. Odd.
Are you using the same device to run Safari and Chrome?
Dazza762
Aug 27, 2021Luminary
raven_au wrote:
Dazza762 wrote:
I'm using that version of Safari but the Orbi site is convinced I'm not connected to my Orbi network. I definitely am as it's the only network in my home. Guess I'll just have to stick to using Chrome for this specific site. Odd.Are you using the same device to run Safari and Chrome?
Yes
- raven_auAug 27, 2021Virtuoso
Dazza762 wrote:
raven_au wrote:
Yes
Then that is really odd, it shouldn't happen.
Unfortunately I don't have Safari on a computer to check, only a phone, sorry.
- Dazza762Aug 27, 2021Luminary
raven_au wrote:
Dazza762 wrote:
raven_au wrote:
Yes
No apology necessary :) I'll just have to use Chrome. Not the end of the world for one website.
- Mikey94025Aug 27, 2021Hero
It sounds like for some reason your Safari browser is caching an old DNS entry for oriblogin.com. When you are not on your Orbi network or if you are not using the Orbi in Router mode, then it cannot resolve orbiogin.com to your router's IP address, instead you get the public IP address for it which points to Netgear's web page that says you need to be on the Orbi network.
Try flushing Safari's cache and see if that fixes it: https://www.idownloadblog.com/2019/01/07/clear-dns-cache-mac-iphone-ipad-safari-chrome-firefox-opera-howto/
