Bobcat55
Jun 26, 2021Follower
Using rbr50 as a access point
Can I use the RBR50 and its two satelites as a access point for a CBR750 with one satelite if so how? Thanks
michaelkenward
Jun 27, 2021Guru - Experienced User
Should work.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but the RBR50 and CBR750 are very different devices with their own technology, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
and
Orbi with Built-in Cable Modem - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check the bits about using the RBR50 in AP mode.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
