Bobcat55
Jun 26, 2021Follower
Using rbr50 as a access point
Can I use the RBR50 and its two satelites as a access point for a CBR750 with one satelite if so how? Thanks
Jun 27, 2021Guru - Experienced User
The 50 series is not wirelessly compabile with the 7 series Orbi. You can connect the 50 series in AP Mode behind the 7 series, however the 50 series would have a separate SSID name.
Bobcat55 wrote:Can I use the RBR50 and its two satelites as a access point for a CBR750 with one satelite if so how?
Thanks
