YouTopia
Nov 16, 2022Aspirant
Using RBR750 as a Satellite? Currently have RBS850 in use with Netgear Router
Was looking to purchase an additional satellite (we have 4 floors and a basement and 4 Orbi satellites) and accidentally purchased RBR750. Is there any way to use RBR750 as a satellite or is it b...
CrimpOn
Nov 16, 2022Guru - Experienced User
No. The RBR750 cannot be used as a satellite on any Orbi system (750, 850, 350... doesn't matter.)
Return it. Sorry.
- YouTopiaNov 16, 2022Aspirant
Thank you! I *think* that RBS750 and RBS850s can both be used with Netgear Routers, though - anyone have experience with this?
- FURRYe38Nov 16, 2022Guru - Experienced User
The RBS from Orbi AX systems can only be used with the Orbi AX RBR units. They will not sync or connect to NH Nighthawk model routers or MESH systems, thus are not compatible.
- W1lliamNov 16, 2022Virtuoso
RBS750 and RBS850 can be mixed use with RBR850, or RBR750 as of today
