techmanrod
Jun 18, 2022Follower
Using same SSID for 2 different Orbi Mesh systems
I have a CBR750 cable modem and satellite and they work well. I received last year, a RBRE960 router and 2 satellites. Together, the two systems give me good coverage in my 2 story house. I setup the...
Jun 18, 2022Guru - Experienced User
You can name them the same but your roaming won't be as efficient and devices might be sticky. You'd be better off to either leave them separate or like you said, use the cbr750 as modem only.
How big is your home? the RBKE963 provides quite a bit of coverage.
