Jsalmon's avatar
Jsalmon
using Starlink with AX4200 mesh system
I have followed the instructions and bypassed the Starlink wifi to push through the the Orbi system but am not getting any internet connection, are there any internal settings that need changing to make this work?
  • Thanks for your replies, i managed to resolve the issue with a factory reset in the end and setting up the Orbi system as a fresh install. please note that following the factory reset the Orbi app no longer connected to the router so I had to uninstall that and reinstall it to get a connection again. and again even though I set up the same network names and passwords as I had previously I did need to go and reboot and reconnect several devices which I think was down to IP conflicts.
    Anyway now up online with Starlink and it's a pretty good connection averaging 240MB down and 36MB up
