tomsavini
Feb 19, 2022Tutor
Using the RBR 750 as an access point
Hello all, Vi have a Netgear Orbi RBR 750 with one satellite. It is working just fine. No complaints from kids/wife. I did set it up to get one more WiFi network to separate it from the wired...
Feb 20, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
tomsavini wrote:
Hello all,
I did set it up to get one more WiFi network to separate it from the wired network in our house.
The problem is (I think) double nating. Sometimes a device that is wired can loose it's internet connection.
After googeling a lot I came to a conclusion: I want to set up the RBR 750 as bridged or access point. I am not sure if there is any differende.
I did check the manual, but I am not 100% sure of how to do it. If I do anything wrong the kids/wife will have my head on a block :)
I think this is the way to do it. Think;
Disable the WiFi on the router from my ISP.
Connect a cable from the ISP router to one of the Orbi's ethernet ports (not the internet port).
Press the reset button on the RBR 750.
On a PC that is connected (wired) to the ISP's router, try to find the Orbi and set it up as an access point or bridged mode.
Have anyone here tried this?
Thanks a lot for any input :)
tomsavini
Feb 21, 2022Tutor
Thanks for the input :)
The Orbi is located in another floor than the router from my ISP, so I turned off the wifi on my routers IPS and set the Orbi up as a AP. It was much easier than I thought.
I thought I had to reset the router, but the whole process was very easy: changed from router to AP mode.
I hope this willl solve my problems
