grizzlybare
Jul 11, 2024Aspirant
Using WIRELESS ORBI RBS850 with RBR750
I purchase an RBR750 and two RBS750. Everything worked fine. I needed more wireless coverage thinking I would switch out the RBR750 for an RBR850 with an RBS850. Things didn’t work together. Now ...
Jul 11, 2024Guru - Experienced User
Be sure FW on the RBS750/850 is same version of FW as the RBR750/850.
Try syncing the RBS850 to the RBR750 with all other RBS turned OFF.
- grizzlybareJul 11, 2024Aspirant
I’m new at this. How do you check firmware version and how to update?
- FURRYe38Jul 16, 2024Guru - Experienced User
Any progress on this?
