Intensified
Jul 14, 2021Aspirant
Uuuuummmm what? Amazon plug shows up as Satellite.
So, I have something called AmazonPlug5JHQ as a satallite. I am sure it is an Amazon smart plug, and it wouldn't be unreasonable for me to have missed setting up one of them when I changed my SSID, ...
- Jul 15, 2021
Disregard, disappeared after a reboot.
Jul 15, 2021Guru - Experienced User
Is this on the RBK50 or Orbi AX system?
Is this in the Orbi app and RBRs web page as well?
Can you attached the picture file using Choose FIle button on your post?
