Rasta-NY
Sep 14, 2021Follower
V4.6.3.16 firmware
Anyone familiar that there's a new firmware RBK750 V4.6.3.16 firmware RBR750 out for RBR750S
Validus
Sep 14, 2021Luminary
There are Orbi Beta Firmware v4.6.3.16 (RBR750) and Orbi Beta Firmware v4.6.3.16 (RBR850/RBS850)
As they are still under Beta, you would have to request access into the Beta testing group to get them, if you desire to use it right now.
Contact "DarrenM" via Private Message to request Beta access and your reason why:
https://community.netgear.com/t5/user/viewprofilepage/user-id/2257
It's update:
- Speedtest Discrepancy
- Throughput/incorrect speedtest results
- Stability issues
Also tends to help those (including myself - using the RBR850) with DNS Errors, that the previous version helped but didn't fully resolve.
